Hi, everyone! i came back to update my issues.
So I realized that I was getting no spark. I finally got that meter and checked out the magneto and cdi. I couldn't get the meter to read anything on my cdi wires(first build unit) and my mag read bout 345-350 on the soldered wires to the unit. I figure hey, I will just take my old coil off the first build(which has almost turned into spare parts ha). I did that and took my newish cdi and hooked it up to both coils and NADA. I even changed out my plug wire( bosch silicone something or other which worked on my 1st build beautifully for 9 mths) with a new one and still no spark. I dont want to come to the conclusion that i have to replace seals behind rotor. Crazy thing is my 1st motor is showing the same thing when i took off the magneto. Gas mix out the bottom 2 bolt holes under the rotor. I just found a post by 2door talking bout the size i needed to know to change out the stock case screwbolts(suck). Anything i need to know before i do replace them and order a new coil or 2? The old mag I could probably blame on getting wet maybe but this new one I havent got near water but i can smell mix and see the drippage(not varnish).
Now I do admit my last minuteness to being lazy in the winter..Honestly its cause my 1st motor worked fine and i never changed anything on it nor adjusted.(besides tightening nuts and bolts). I do recommend to any newer builder to get yourself a puller and look at those crank seals. After the 'quality' came out of the box i knew i was in for some fun later down the line just not that soon.
