It could be possible you need to go the other way with a 27.5 and adjust it down with the idle mixture screw... Basically if you can't get a lean stumble at idle with the idle mix screw before it's all the way to soft bottom, then the idle jet is too big, same as if you can't get a rich stumble out of the idle mix screw before it stops responding to change, then the idle jet would be too small. The needle position also plays a big role in the off idle and part throttle cruising, then the main jet plays it's part in conjunction with the needle position and the idle jet as well as the idle mixture adjustment.
Other things will also factor in for what jet will run best in that carb... How restrictive the air filter is, or the lack of restriction from the air filter, and how restrictive or free flowing the pipe is will also determine which jet will do best.
A good pipe will need a little more fuel going into the engine and so will a less restrictive air filter.
Try adjusting the idle mixture and make sure you can get both a lean stumble and a rich stumble when adjusting the idle mixture screw and jet accordingly, then set the needle in the middle position and see how it performs at part throttle, raise or lower it accordingly to get it to behave at it's best, then try a full throttle run and see how it reacts, you may need to go up or down a size on the main then go back to your needle settings to get it to dial in. It's definitely a tedious job depending on what upgrades you got and your altitude, then there are other ways to fine tune the off idle by either changing or modifying your slide...
Here's a little more info on these carbs if things get too tricky...
http://www.iwt.com.au/mikunicarb.htm
