Truckd the head is set at 70 degrees. This is my first bike build and I am just using pictures off the net as a reference. I have see some that are 60 degrees and they start to look like choppers to me. If I am making a mistake with this please speak up. I live in Oklahoma.
I was told that 4" is the optimal number to shoot for less rake shorter steering range,longer rake more sensitive(touchy) medium is what is desired and at a high of speed (30+) a limited or wierd steering range could result in a catostrophic mishap.
I was told to pass this info on to add to what you might have already aquired.
www.carbidedepot.com then find the catagory for Rake&Trail Calculator.
Something to do a little R & D on for a bike of that magitude and calabur, you have an Great Deal in talent,don't over look the small details.
By the way, about what do you believe the HP rating would be on that Monster engine?
So it looks like on trail there is such a thing as too much and too little. As in many things in life, moderation is the key for the best handling. It would be interesting to build a variable angle head tube and try out different trail values at different speeds. If I ever do a production run of the same frame over and over I'll try to figure that out.
I built a metal lathe with a file and a drill press so don't let the lack of tools stop you.
