Two bikes for sale
fx-2
Moved to Tucson 7 months ago an have not used the bikes at all . First one it a Worksman frame with all the good stuff , front drum brake ,Monark springer , worksman alloy wheels , Sportsman Pat tank , MM intake and sprocket adapter 40 tooth sprocket , Jag CDI box , expansion chamber and a real Dellorto 16-16 carb . It's plated in Cal. The other bike is a Macargi frame , springer front forks with disk brake . The wheels are HD from Piston bike 12 ga spokes double wall. It has a MM sprocket adapter with a 44 tooth sprocket . The motor has a long intake with a Dax RT carb . A Jag CDI box and a Jag expansion chamber . It has a Push 70 cc high compression head . It too is plated in Cal. Both motors are Jets an are ported and matched to block they have up grade bearing . The Macargi has about 20 miles and the worksman about 300 miles . http://motorbicycling.com/showthread.php?t=43040 http://motorbicycling.com/showthread.php?t=38833 links to builds and pictures . Thanks Dan
I would of thought some one by now would of made a offer on one of the bikes . They are for sale one or both . Worksman is priced a 1200 and Macargi at 600 .Thanks for looking . Dan
