Russell
My engine that has run well for about 3-400 mi.
It started skipping and a little backfiring. Sometimes it would run fairly well then start skipping or not run at all.
Checked the plug it was burining a little lean. Changed plug and wire with a known good ones(no change).
Checked wiring connections including magnito ground(looked good).
I thought it might be a fuel filter problem. Changed the filter(no change).
Next thought CDI!(wrong) As I was changing the CDI, I saw a tiny wear mark on the brake sw cable.
It had vibrated and worn thru the insulation on a bracket. turns out that was the problem.
I hope this might help someone when they are experiencing similar symptons.
