Tricycle Options...
lilffihn
Hey Ther Everybody...i Was Wondering If Anyone Had Put A 2 Stroke Engine On There Trike...not Like A Recumbent Trike But Like A Sit Up One...i Was Thinking Of Doing This So I Could Ride It In The Winter So I Wouldn't Slip On The Ice And Snow...thanks For Your Help...
Hi,I'm going to build a Trike with a 4 stroke bike engine kit, I purchased a nearly new Workman Trike for my base build...Pete
Spookytooth sells a tricyle converion kit for bicyles....Scroll down and it shows alll the pics of the bike when its done....
Tricycle Conversion Kit for Bicycles & Motorized Bicycles
John-John.trk
That Tricycle conversion if to make a two wheel bike a three wheel bike.
I want to buy a Schwinn Tricycle and add an engine to it....
I haven't dealt much with motorized trikes.
I have read of others' efforts for normal (non-motorized) bicycle/trike conversions.
The main drawback of these kits is that unless you can do machine-shop work (or you pay to have it done) you are limited to only a single-speed or a 3-speed setup. All of these "granny" trikes I've seen, including the "industrial" ones from Worksman and Husky, all only offered a single-speed or a three-speed option. If you live anywhere there's hills, three speeds isn't going to cut it. The "bicycle" hub needs to have a second cog fitted to the left-side spoke flange, that is used for the shorter second chain to drive the rear axle.
A second problem I have heard of is that these kits are not built very rugged. They have problems with bearings going bad, the rear frame cracking and so on. I don't know that they are all the same, but most of them (from lots of different sellers) appear to be identical. Some of the low-rider sites sell them very inexpensively.
I built this out of a west coast chopper made rear out of 3/16 plate and dom tubing 3/4 axle shaft, hand built fenders. front and rear disc, hand built exhaust
