John the Chimp
Hey guys, as you all know the Grubbee 66cc. motor leaves alot to be desired. To say the least.
I had a ring break and stick the piston. Not repairable.
Now mind you the motor is less then a month old. Was broken in with 16:1castor 927. Then only went to 32:1.
When I asked about warranty I was told it was more expensive to mail it back to try to have the factory replace factory defected parts. Ok whatever.
So I just bought a new topend.
I know I need to clean the cast flashing out of the intake and exhaust ports and polish of coarse. Im also polishing the piston,wrist pin,rod end, and needle bearing.
Here are the questions. Should there be a bump or wall in the roof of transfer port? Or is that flashing? Should I remove it? I know pics would help but I am on my phone.
How much if any do I need to clean up the transfers?
Thanks in advance for any and all help or advise. I would like to help one of these azma sufferers breath better. Lol.
