OK, so hopefully you guys can give me some insight as to what my problem is..........my bike has still not been completely ready for riding yet, although I've taken it for a few test rides around the block. I have a Broped 80cc kit.
My throttle cable just broke, and I replaced it with a new one. My throttle worked before, but now, nothing happens when I twist it. You might think that the new throttle cable isn't hooked up properly, but I am pretty sure it is hooked up correctly. The throttle handle twists back, and it pulls the cable to open the valve in the carb just like it is supposed to.
The engine kicks in when I release the clutch to start it, but nothing happens when I twist the throttle. Hunter from Broped said to check the wiring, which I did, and I'm pretty sure that is all connected good as well. Unless it is something inside the ignition box?
Hunter also said it could be the Chinese spark plug.....I looked at that, and it didn't look burnt or anything like that. I was told to buy an NGK B5HS, but the tip of the B5HS is a little different, and it won't fit in the connecter.........ANY ADVICE ON SPARK PLUGS OR IDEAS WHAT THE PROBLEM MAY BE?
Thanks guys.
Thanks guys.
