Technocyclist
Hi All,
If you're thinking about an aftermarket connecting rod, then you might want to read this article first.
http://www.faliconcranks.com/Making%20the%20Connection.pdf
Well, in summary, basically, there are different designs of connecting rods and different materials. Making the connecting rod lighter can increase up to 1000 RPM without causing damage to the engine, but I dunno if this applies to the China Girl. This would also lessen the stress on the needle bearings and piston.
So, I'm thinking if I replace my connecting rod with an aluminum alloy one, it might cause an out of balance rotational forces to the cranks... hmmm, but I think it's worth to try.
I'm also thinking of drilling holes on the stock connecting rod to make it lighter, but this would sacrifice structural integrity...
what do you guys think? Has anyone tried reducing the weight of the connecting rod?
BTW, so far I've encountered 3 sizes of connecting rods, but correct me if I'm wrong. These are: ZAF 50, ZAF 60, and ZAF 80. The higher the number, the longer, and therefore heavier. I've used ZAF60 and ZAF80. My Engine with the ZAF60 seems to have more power and runs smoother. Engine with the ZAF60 has a longer piston. So if you're ordering parts, check out the number on the connecting rod first.
With this in mind, since there are different sizes of connecting rods, and all (I assume) are using the same cranks and counter balances, so I think it would'nt hurt to replace the connecting rod with an aluminum alloy. Well, it might hurt my budget though...
There had been a lot of threads about porting and crank balancing, but I guess the connecting rod is equally important...
