This is a bike I built a few months back,
My Wife and kids were a way for a few weeks, and although I already had a couple of quite fast bikes, I saw this tiny little 24" 'Teenagers' bike at a Pawn shop for $100 and it looked in good nick and had a three speed hub on the back which I wanted for my FTC tadpole trike.
I doubted I'd be able to squeeze a motor in it, but just 'fell for it'.
Got it home and realized if I tried hard enough, a motor would just fit!
I got a '70cc' motor of Ebay, to find it had a 40mm crank, but a 45mm piston and 6mm head studs.
So I redrilled the cases for a set of M8*1mm head studs, Stuffed the cases with 3mm alloy 'street sign'. Got a good 47mm piston and barrel which were then ported, polished, lightened, and match ported, and reshaped the chamber on a 'chromed' angle fire head, made copper gaskets for everything and gave it a coat of black after filling as many casting flaws as I could be bothered.
I had her running real nice with a speed carb , fairly standard exhaust, and a 36t sprocket, letting me take off from a dead stop with out pedaling and getting to and holding a bit over 60 Kph. It didn't want to do any more than about 8000 Rpm as I remember, But got there quick.
Then I had an idea for an expansion chamber for her, and made a manifold for a'16mm' Walbro rep, that I had bought for a pocket bike motor that is going in the FTC Trike. Which are much better to try and tune to a pipe than the speed carb. And is a much neater fit also. I had her doing 70 Kph and 9000 Rpm when I blew the head gasket due to using recycled head studs and nuts.
So I got a 'new' set today, and When I get a chance I'll pull her down and give you all a look inside.
