Deacon - regarding the discharge rate you talked about above: many batteries (especially lithium) are rated for the discharge rate they can tolerate. It's called C rate. You talked about it regarding charging a while back, I think. It is a multiplication factor of the ah rating. The 20ah Elite Thunderskys I'm trying out are rated at 2C continuous/10 C impulse, so that works out to 40 amps continuous. That's plenty for my 24 V 350W motor. I tried to find out what the average C rate is for NiMH but it appears you have to check each manufacturer's specs and do some calculations. You could go to some of the RC forums and check it out if you want. I think that could be a reason your early testing of the 10 ah pack ran like a pig, as you said. Here's hoping the full set works better. The Prius uses NiMH, so there must be something to them.
BTW, I took the Thunderskys out for a 7.5 mile ride yesterday. I left with them fully charged at 30.2 volts and returned with 26.5 volts. That is 2 of the "12.8 volt" packs in series. 26.5 V is about what my SLAs are at fully charged, and they're usually all in (21.5-22) after 7-8 miles. They used to go twice as far but my careless deep discharges and overcharging have really hurt them. I'll continue to report my results as they come in, but the deck has a coating of snow as I write this, so I probably won't be riding tomorrow - jd
