I know this is a gas loving group here, but I've been reading like crazy about ebikes for a while now and simply must share my reading. I'm incredibly impressed with the performance some of these things put out, and I want something with power, long-term reliability, and easy maintenance. I'm plotting a mid-drive, full suspension downhill ebike capable of 60+mph/12hp/9kw, and 100+ mile range @ 30mph. Thing about ebikes, with the controller I'm considering I can go from zero to full-torque in 2 milliseconds... so the DaVinci drive's torque slip is a crucial function to prevent throttle-twitch crashes. Wheelies are cool, but I'm not crazy... instantaneous 12hp? No thanks =D
**2003/4 Giant DH Comp 21" with good forks,something like this. Though I've recently started leaning toward a 2002 Rotec.
**Astro 3220 in DaVinci drive reduction system for cooling, mounting, torque limitation (no wheelie crashes for me!)
**sinusoidal vector-field controller, if this one hits the market in time.
**~2.2kwh of Headway cells, probably 72v/30ah (24s2p) config.
**Welded-on compartments for batteries/motor mount.
I made a mockup that was inspired by this bike and so used a Crystalyte x5405 hub motor, but that's 24lb's and not as powerful or efficient as the 4lb Astro motor. So I'm ditching that, but haven't made a new model yet. Here's the old one one of several battery configurations, ignore the giant motor by the crankset:
Note that in staggered formation, the batteries total 7" wide with the frame between them, with a case they'll be about 8". Since I'm ditching the Crystalyte motor I'm going to reconsider mounting the batteries radially around the down tube; that'll take advantage of the inner triangle space I selected the DH comp for, and keep them out of my pedal range. I'll decide when I have everything; I may like having something to hold onto with my legs while I'm going 45mph =) Or zipping through trails...
Depending on speed, incline, wind, etc. the efficiency will range from about 20 to 60 watt-hours per mile (Wh/mi) so the electrical cost is .72 to .24 cents per mile, while the cost of battery wear comes out to .48 to 1.44 cents per mile. That means it costs, at most, 2 cents per mile to operate... but on the low side (30mph), it gets the equivalent of approximately 600 miles per gallon. The downside is that most of that cost is up front in a $1,500 LiFePO4 battery pack. I could go with a MUCH smaller, cheaper, but shorter-lived (cyclically and range) LiPo pack, but I'm not. Another upside is that free EV charging spots are being put in all over the west coast, including on the interstate...
I'm going to mount the BMS and charger inside an Otterbox DryBox and mount that on the top tube behind my bars; it's out of the way, gives me a place to put important items (e.g. keys, wallet) and makes it easy to take the charger with me everywhere. I'll just leave everything hooked up, leave a cord in there, and then I can just pop it open and plug it in anywhere. I'm strongly considering getting a ~3kw charger despite the cost, just so I can take this thing on the interstate and charge it in 30-45 minutes before going another 100 miles or so. I'm also planning on putting a Freeload rack on it. =)
Anyway, thought I'd post here and hear thoughts =) You guys raised me into this hobby, after all =D
