The Carb
Discussion in 'Motorized Bicycle General Discussion' started by Jim C, Aug 30, 2010.
  1. Jim C
    Jim C Member
    Jul 11, 2010
    191
    I took the bike out for it's first long ride, well about 20 miles. By the time I got home the idle was at about way too fast. I discovered that the whole top of the carb had unscrewed. I have always thought there was an air leak & it always idled too fast, the air screw did nothing. After fixing the carb I was able to set the idle. I road it for a few miles this morning & am very happy. These concentric float, cable slide carb used to be a main stay of motorcycling. Most have 3 circuts 1. the idle or float lift 2 the mid range or needle circut 3 the high speed circut or main jet. They usually have a stop or idle adjustment. This little carb has no idle adjustment except for the cable adjustment. The air screw probably is for low speed to mid range tunning. I did use it to bring down the idle and it all seems ok. It runs a little rough at 10 mph or so then smooths out over 15 feels good with a load on it. With the gas on it pulls right through the rough spot. Unfortunatly 10 to 12 is a good bike lane speed. I will get this all dialed in.
    Jim C
  2. Jim C
    Jim C Member
    Jul 11, 2010
    191
    That should be The Carb
  3. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    The screw on the side is your idle screw. All it does is prevent the throttle slide from closing all the way, with a pointed inside end. There is no air screw. As you know, there's no pilot circuit, either. Single jet, with a tapered needle to marginally adjust fuel flow between about 20% and 80% throttle. There's really no simpler carb.
  4. r00t4rd3d
    r00t4rd3d New Member
    Aug 2, 2010
    310
    If you want to be able to tune your carb get a Mikuni 18mm off ebay. They are the same price as the "Racing Carbs" but alot better product.
    #4 r00t4rd3d, Aug 31, 2010
  5. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    The thread title sounds like a movie.
    One man, one dream. To create a bicycle faster than ever before....
    Jim C.......THE CARB
    Coming to a theater near you.
