knightscape
Sanity check please? I've got what should be a real simple question about a tachometer on a 4 stroke. I put the Trail Tech TTO on my HS142, and it's default setting is 1 spark per RPM, which I thought was the setting for a 2 stroke. It has settings of 0.5, 1.0 and 2.0 for sparks to crank rotations. I thought I'd figured out that the 4 stroke needed to be set at 0.5, but on that setting it's showing my cruising RPM at up in the high 13k to 14K range, which should be double what it is. So is the correct setting actually 1.0 for sparks to RPM on a the Huasheng? Do the HS142's waste an unneeded spark on the exhaust cycle? Now that I'm thinking about it, the magneto/CDI would spark on every rotation, so 1.0 would be correct? Thanks!
