The 12 inch tire is required to handle BMX sprockets at 18-22 tooth. I could not find a satisfactory rear hub at 12 inches that would lace.
A larger rear hub requires a larger rear sprocket. The largest available for a IGH is an sram 24 tooth. Maybe you could lace an IGH to a 16" hub with the 24 tooth and chain directly to the tranny.
a 26" tire would need a 32 to 44 tooth input to achieve direct coupling to the tranny.
So, if you were to run a 49cc foot scooter/utility motor with the 5-to-1 tranny output on the right hand side (opposite of a china girl engine) , Install a 32 tooth rag joint or manic mechanic style clamp on precision preferred, purchase THIS
http://www.niagaracycle.com/categories/torker-tristar-sturmey-archer-3-speed-coaster-brake-hub
..And move the output sprocket to the other hub-flange to drive the 32-tooth sprocket on the LEFT side of the bike. In other words, use the sturmey version to cross over the drive-train/rim. use the nexus version to drive the same side of the rim.
For pure china girl implementations, with BUMP START and manual CLUTCH, purchase this
http://www.niagaracycle.com/categories/sturmey-archer-s3x-3-speed-fixie-hub-kit-36h-120mm-silver
Install the bolt mounted sprocket on the S3X hub and orient the sprockets to the LEFT side of the bike. Yes the S3X is a fixed gear 3 speed, and can both bump start and drive. 3rd gear is 1 to 1 so use a 22 tooth sprocket on the rear wheel, or 32 tooth in hill country
Specialty kit , install stronger springs in this unit and utilize as an auto-shifting jack shaft.
http://www.niagaracycle.com/categories/sram-automatic-2-speed-hub-freewheel-no-brake-36-hole-130-0mm
My next experiment is with the I-motion hub. wider range three-speed and my goal is better response for shifting when the centrifugal clutch wont let go at mid rpm's.
http://www.niagaracycle.com/categories/sram-i-motion-3spd-coaster-brake-36h-hub
The king of the jack shaft IGH is the Spectro P5 , 'Cargo' version if you can get one. You need to provide the second sprocket for the spoke flange to use it and 49cc will get action in all 5 gears.
Modern IGH hubs provide thousands of trouble free miles when properly matched to the engine with the right gearing. My nexus jack shaft spins 1200 RPM at max engine torque 2 40+mph.
Thats all I know. I get off on slamming gears more than anything else.
