So today I was riding my MB around town and the bars came loose. It's an HF 79cc 4-stroke, stock, on an Electra Cruiser bicycle. Does about 39mph on the flat and I've had it up to 46mph down a steep hill. Not sure what the gearing is, but it's pretty tall, as the acceleration isn't good but the top end's fine. There are pictures of what happened to the bars attached, but essentially the threads on the bars stripped and the bars were left to move freely in the headset. I had to ride home with my bars moving 360 degrees which was less than ideal but doable if you had to. The bike's unrideable until I get the bars fixed, but I've been thinking about shorter, straighter bars or even clip-ons, and this just gives me an excuse to do it. I've got a 212cc bike in the works, but I need something I can ride until that's done so I gotta fix this bike.
My guess as to what happened is that I went over a speed bump a little too fast while holding onto the bars and it put enough pressure on the bars to strip the threads then and there. That coupled with the wear over time from the engine's vibration probably did it. If this has happened to you, let me know, because having this happen while I was riding wasn't a good experience.
Update: I took a look at it and even with the screw on the headset that puts pressure on the bars and keeps them from moving fully tightened, they still had play. I took JB weld and put it on the threads and got it back together and I think it's good to go. I'll probably figure something out on my next bike to keep this from happening.
