stock replacement throttle sleeve
Hey all, was wondering if ayone knows or has tried a replacement throttle sleeve/tube(on the handlebar) that can be bought from a motorcycle or scooter dealer that they know works 100% with the stock ht kits. Just need the sleeve/tube only don't want to buy a whole new switch and grip assembly and it is cheaper to go to the local motorcycle/scooter shops instead of shipping to Canada. Make /year/model that you used would really be appreciated.
Cheers!
i'm pretty sure any (or at least, most) throttle tubes that fits a 7/8" handlebar will work. i've got three different ones, and the tubes are all the same size. one's for a honda dirtbike, one's from a junkyard bike, and the other's the stock plastic piece of garbage.
motorcycle shops should have a replacement that'll work.
I have a stock replacement sleeve...if you PM your address I'll mail it to you. Aftermarket wise....I've found that the sleeve (7/8 single) is pretty much standard. The difference is what is made of (plastic, metal).
