Hey guys I just picked up my motorized bicycle last night. Did a few laps and then took it home!
Upon testing it I did notice I have to hold the clutch halfway or atleast 1/4 the way to keep the motor running. If I completely release it the engine dies out.
Any ideas? Tried pedaling down hill this morning and popped the clutch it won't fire up.
Pull the spark plug and be sure it is grounded good on the cylinder head and check for fire. If this is a 80/66 2stroke china model you can turn the back wheel with the clutch pulled and check for fire. If you have good spark it will probably be a lack of fuel problem. you may also go ahead and clean the electrode on the spark plug while you have it out, look at the color on the plug before you clean it. if it is black the plug is probably fouled. also see if it is wet with fuel if it is wet then it is getting fuel. if it is white and dry it is not getting fuel.
