Sprockets and gear for freewheel shaft
67 rider
Iowa
need information on best way to build or buy a system for a drive on a GC-160 engine to 3/4 crank set shaft. engine clutch to crank set , crank set to rear wheel sprocket. I looked at Sporstman Flyer gear system ($250.00 but only sells in his kit ONLY ! Are the 2 sprockets welded together on a bearing of some kind.
Thanks
curtisfox
5,981
3,750
minesota
Thanks
Contact him he may sell parts separately, he has the best .........Curt
Agreen
792
11
Southeastern GA
The gc-160 comes with either a tapered shaft or straight shaft, depending on which type you get (v type or q type, respectively)
If it's a 3/4" straight shaft, you can use the comet cvt (also known as the torq-a-verter).
