diceman2004
for anyone who needs to figure out the diameter of any given sprocket
simply multiply the pitch of the chain , by the number of teeth on the sprocket
then divide by 3.14
Number 35 Chain: Pitch = 3/8" | Roller diameter = 3/16" | Roller width = 3/16" | Pin diameter = 1/8" | Tensile = 2,100
Number 41 Chain: Pitch = 1/2" | Roller diameter = 5/16" | Roller width = 1/4" | Pin diameter = 1/8" | Tensile = 2,000
Number 40 Chain: Pitch = 1/2" | Roller diameter = 5/16" | Roller width = 5/16" | Pin diameter = 5/32" | Tensile = 3,700
eg: - whats the diameter of a 72 tooth sprocket , that uses number 41 chain ?
.500 x 72 = 36
36 / 3.14 = 11.464 diameter
NOTE : This is the diameter at the center of the chain roller , so you can also use this number accurately in calculations .
The outside diameter of the actual sprocket will be roughly 3/8 - 1/2 bigger at the tips of the spurs .
then divide by 3.14
.500 x 72 = 36
