Oh yeah and jburr36 does the resistance you feel have to do with your clutch or something?
I got the same junk sprockets from BGF. I sent an email and they told me... No charge for the extra holes. What a jerk! My engine also came missing the blue wire.
Well finally got it aligned and the engine is running. Need to tune the air ratio or whatever. Will put up some picks soon. The sprocket already looks a bit misaligned hope it holds up (the wheel that is)
My friend is helping me put my bike together and he has it at his shop right now. Its 80-90% done but we've run into some hiccups. He took the thing to his work today and said that the sprocket is off by 3/8 of an inch or so. The sprocket is mounted with the donuts on both sides. He thinks that he will need to grind them down to get the sprocket into alignment.
Also the idler pulley needs to be modified. Who knew it would be so much hassle to get this thing up and running. Heck putting on the rear sprocket took about an hour without having to align it. Oh yeah and the sprocket had to be machined to the wheel hub to get it to fit. Well at least alignment is perfect in that sense.
Has anyone else had similar problems???
Thanks
you might try removing the donut on the outside of the spokes, there usually about 3/8" plus with the sprocket against the spokes it will bolt down true. you have already machined out the center hole, should make for any easy install.
