sprocket adapter with disc brake
dirbob
here is my version of a sprocket adapter and am adding disc brake to it (tired of panic stops). after completion am going to try to run both calipur and disc brakes on same wheel. My clamping mechanism leaves something to be desired. So if i get any movement at all will put rag joint back in to stiffen it up. have a nice day. bob
mk didn't use wide axle just machined spacer to fit what i had then hung calipur on outside. just took a cut off bolt and machined it down to fit bearing. then drilled and tapped it to axle threads. in my case 10mmx1.0 (it varies). that way brake should run true even if you have to adjust wheel. Still have to make setup so brake is self centered(a work in progress). Good luck on your endeavors. bob
i wonder if there is a way to get the break to fit the sprocket and mount it at the front half of it so the chain could clear it?
mk yes there is a way to do exactly that. it already has been done. not sure if the thread is on this site or motoredbikes.com. a guy had a real beautiful setup. thats what i was originally going to do until i found out you could get brake and calipur for $25. i already had the parts to make just what you are talking about, but you run into real clearance problems. can't remember what the guys thread was called, but he did a real beautiful job but looks like he made his own calipur. bob
mk found it on other site. search for "home built disc brake." its worth taking a look a beutiful job. bob
This is what I did. I just had to grind a little off the caliper mount and use a smaller spacer between the spokes and the sprocket. Works a treat.
