bobmcmillen11
Hi. This is my first post. I've had a BGF 66cc for a few years with no problems. I used it on a box store urban bike with direct drive, and then put on a SBP shifter. The engine hasn't had much use, probably 5 to 19 hours. Then I saw the skyhawk gt frame and had to have one. It was more trouble than I expected, wrong wheels,brakes, seatpost, etc. Everything is together now but I can't start the engine. Spark is good and timing is acceptable (around TDC). I've tried two carburetors and even tried some starting fluid. All I get is an occasional pop. Compression feels normal but I didn't use a gauge. I did take head and cyl off to check the rod (LEV) so it's a PK80. Any suggestions? I guess it has to be the rings.
