SuedePflow
Thanks for the link!
Do most people only adjust clip position to change mixture, or is it also common to change out the jet?
Anyone got a link or video that explains how to play with jet sizing and clip loactions? I'm new at this stuff and have a Speed carb that bogs badly over 80% throttle. I'm guessing it's running too rich.
Some times it takes changing both. Changing the jet changes the mixture differently than a needle clip change. Sick Bike Parts should have jets. Get the number off of the jet you have and buy one or two either way from what you have-two richer and two leaner. They don't cost much and you can experiment with them. For the clip on the needle the closer to the top of the needle you have the clip the leaner it will be.
The "Speed" carb is the same throttle bore as the stock carb so one should perform the same as the other.
Jim
I checked the plug in mine today and it's definitely rich. I'll set the clip a notch leaner and change the plug and see what it does.
Just to satisfy my curiosity, where can I learn about how to change the jetting?
Jim
