Some kits come with a Z4C spark plug, some kits come with a Z8C spark plug.
They both cross-reference to the same thing, so why the difference in the numbering?
The heat range numbers are clear, but it seems that the Chinese are not following that convention.4 or 8....heat range...8 being colder then the 4
Al,
Just curious why you always suggest to replace the high voltage lead. The kit supplied one, solid metal conductor, is better than what you'll get at most auto parts stores today. Everyone I've seen, with the exception of copper core on bulk rolls, is resistance wire. And not high performance wire either just standard old carbon impregnated thread as a conductor which doesn't lend itself well to the screw in CDI connector.
Don't believe me? Try using a good ohm meter, test the kit wire against the same length of auto parts store wire. Our little underpowered ignition systems need all the help they can get and that doesn't come by adding resistance to the high voltage side.
This chart shows both types on the same line, as if they are the same:
Spark Plugs|spark plug|K6TC|A7TC|F5TC|E6TC|D8TC|Z4C
Then by all means I think you should use brake cable. Go for it. Even that will be better than resistance wire. At least there's a metal conductor in there somewhere.The heat range numbers are clear, but it seems that the Chinese are not following that convention.
In response to 2Door's comments, I think that it is a stretch to even call them a spark plug wire or or ignition cable. To me, they look more like a plastic tube or hose with a couple strands of copper wire shoved thru 'em. Although I never tried it, I think a piece of brake cable housing (with a steel inner lining) would work better that what is supplied with the kit, plus it already has a hole in the center, ready to accept the CDI screw.
