Bought this exact kit (with bike) here: https://www.gasbike.net/collections/motorized-bicycles/products/jet-66cc-80cc-motorized-bicycle
I'm mounting the engine, and am finding that the spark plug (without the wire attached) barely clears the rod across the top of the mountain bike. I feel I will have to mount it slightly leaning to the left or right to have clearance to put the spark plug wire on, which I know will not be good for the chain. OR I could lean it forward or back a bit but then the air intake manifold will not be parallel with the ground as the instructions indicate.
I wish that the spark plug leaned forward more, like in the picture of the kit.. then it'd definitely not nearly touch the rod across the top of the bike. (seems this might have been an issue before and has since been corrected, but apparently not on my engine)...
If I remove the spacer between the engine and the seat rod, the engine goes too low on the bike and might interfere with pedaling. Any suggestions? Just a picture of this motor installed on this bike would be helpful but even the site doesn't have one.. :-/
Thanks very much! First installation but DEFINITELY not my last!!
