Sound Dampener "Before" and "After" Comparison
Nashville Kat
1,503
55
48
Jacksonville, Florida
I made some dampeners of my own today and put in the 50cc build (which is temporairly down)
I used some poster mounting backing board from a Dollar store- sorta like extruded styrene- only just 1/8" thick- and I stuck some thin pie plate aluminum, from a store-bought pie over that- used a little gasket sealer on both sides of poster foam board-
Won't be testing it for a week or two-but it's actually a bit thicker than the Damp-Pro, and the 50cc is a little more quiet than the 66 to begin with- Didn't do any "before" video- the motor's apart and I just wanted to get it done-Had all the stuff, so it cost nothing.
Have taken several trips now on the 66 in the vid- and the Damp-Pro dampeners don't seem to be any problem otherwise. I'm pretty happy with the whole thing.
decoherence
476
sebring,fl
thanx for posting that. now i can identify what the "gear" sound everybody complains about.
i guess i will go get me some sound dampening.
Nashville Kat
1,503
55
48
I think a longer pipe also cuts a good bit of noise- except maybe an expansion chamber-
I had to cut a poo-poo pipe to extend it below the bottom bracket
but here's a nice alternative that may be just a bit more quiet than a stock muffler- with another six inches of pipe and a little longer muffler-
and not priced too far above a standard replacement
http://www.gasbike.net/bike-motor-engine-fancy-crome-pipe.html
has anyone tried this pipe?
vincent713
287
Dallas
I haven't tried this pipe but I like it alot. I wonder how much noise reduction I would get from this pipe and would I need any modification?
Nashville Kat
1,503
55
48
I haven't tried that pipe, but do have a longer one-
It's all like blowing through a horn- the longer the horn, the lower the tone will be-
It would take some of the high end off- with that pipe in the link above it looks like you'd only be adding about 8 inches or so of pipe, maybe ten- it would be minimal,
but if I was needing a REPLACEMENT muffler for the kit-for the price, I'd probably order one-
my 50 motor is already a little more naturally quiet than the 66-
Hey maybe I'll shoot just a short video of it with the kit muffler and homemade dampeners and compare it to the other.....
Nashville Kat
1,503
55
48
"Dampen"-1. to make or become damp. 2. make less forceful or vigorous, choke.- Oxford Dictionary
a similar more lengthy definition applies to "damp"
Both damping and dampening are correct
The Sound-Pro Product Description at Pirates uses both terms-
Hate to say it and discourage commerce, but I think the homemade dampeners I put in my 50 cc actually work better, with 1/8" styrene poster board backing from a dollar store under a thicker store bought pie plate- although it rubbed off some aterial near the center I wiped away upon inspection.
I think the styrofoam material absorbs more sound than their tar substance and my aluminum is thicker too.
Another note: BE SURE TO TIGHTEN THE COVER SCREWS WELL- I lost a couple, but had replacements-
I think eventually I may get some titanium bolts to replace them when I have more money
vincent713
287
Dallas
Now that English 101 session is over........so where exactly did you put this dampening material at? I want to dampen the centrifugal clutch cover but it's a tight fit and I don't want anything rubbing on the clutch. Any input is much appreciated.
diceman2004
564
Kitchener , Ontario
if you have an old seatpost kicking around that you don,t need ... try this .
Mind you , I did this on my 97cc 4 stroke .
1 : the post NEEDS to be one with rolled in rounded ends .
the inside of the seatpost is bigger in diameter( around 7/8 ) than the hole on the rounded end ( between 5/8 and 3/4 ).
( this is important ... so don,t go cutting up a seatpost , if ya don,t know what i,m sayin ... ya know what i,m sayin ? )
2 : you are going to use the bottom end - not the end that the seat attaches to .
3 : cut about a 4 inch piece off the bottom end
4 : hold this saw cut end over the outlet of your muffler . you want the rounded end to be the end of the muffler .
sounds cool EH !
Nashville Kat
1,503
55
48
Hey Vincent- look at the video again- in the middle when I open the deampener package-
there are three - one for the clutch cover, one for magneto and one for the sprocket cover-
I didn't add the sprocket cover when I put my opwn in the 50 because it is open there anyway and you have to mess with the cable a bit.anyway- It to it may block some sound, but I didn't bother- the lightweight 415 Trike chain DOES run quieter though- see thread in General discussion-
http://motorbicycling.com/f3/im-really-jazzed-over-new-chain-34585.html
I used 1/8 material from the dollar store- the school supplies- and it's poster mounting board I think- I cover it with pie plate because I didn't know how well it would stand the heat and to keep any chewed material out of the motor- You may get awy with no aluminum or pait or glue tin foil--
I didn't cut quite enough of a hole in the middle- see patterns in video- and it chewed a little bit of material around the edge of the hole- but no problem- the motor had it's way!
It's all thick then- about 3/16 I guess- I think the Sound Pro store bought are thinner
You can use cardboard I hear- but I tried to make something more permanant- although nbow I see that the covers aren't difficult to remove.
F_Rod81
Dealer
Jan 1, 2011
1,031
Denver, CO
Good job with your video. Not much to say, the stuff works. I have had the Damp. kit for over a year now. (^) I recommend it for those that don't have it.
