Soldering wire connections not recommended.
One thing to watch for with the kit crimped bullet connectors is them crimping the connector onto the insulation with no conductor connection. I've seen two of these, both were the blue wire on the magneto side. They had cut the conductor off and crimped the connector onto the insualtion. I don't know if that was intensional or a mistake. Just make sure you have a good electrical connection before relying on the kit connectors.
I solder
I crimp but hate cheap terminals and use channel lock crimp tool.
I solder all ground ring terminals.
Installed several hundred remote starters, soldered all connections.
Soldered everything on my bikes.
