Snap Crackle Pop, Power Drop?
I drilled out the last 2 screw bolts, now I am down to the small gear, the motor is apart though, crankshaft not separated.
And as for the impact driver I was using it wong, the wight way I discovered is to put a little torque on the screw bolt, then whack it.
been a while since I saw someone new to impact drivers - next time you need to extract a broken stud, you can fit a socket to hold the extractor bit and usually get good results with that too
The cause is determined to be the lower piston rod bearing disintegrating.
I need a new crankshaft assembly, and a piston, ring, cylinder kit.
One would hope for better reliability with new parts, but....
Yeah, sure.
You see there is one major problem us Canadians have, availability and S&H, a lot (not all) of those cheap $90.00 motors on ebay are not for sale to Canada. Besides, have you seen what they charge to ship it out? A lot of people just see the price, not the S&H charges.
At speeddemon.ca all my parts will cost me about $121.00 including taxes and S&H, to buy a whole new motor would cost me a whole lot more than that.
I get to rebuild my motor myself if I buy parts and better bearings, that's priceless.
But, and that's a big one!
C $93.01+S&H+ C $17.78+ import charges C $16.16 = $126.95
BGF $135.38
OK, so, maybe I should get a replacement motor from ebay, and work on rebuilding my motor later.
ALRIGHT, so that's not too bad actually, but what am I getting? Should I get the BGF, with the wider intake?
So what, they are all a CRAPshoot anyway
Up to you. You might have more damage than you realize and you might still be dead in the water while you're waiting on a new engine. And another plus for installing a new engine and doing the workover, is that your down time is less and you can work on your old engine and then have a spare.
That's the plan now DD.
I think I have learned that I should take my new motor apart and inspect it for metal filings and shavings or at the very least give it a few rinses with varsol or kerosene with the jug off and I will work the piston and crankshaft to flush out any metal shavings or filings out of the bearing.
Then lube it afterwards with oil.
May even be a good idea to strategically place a magnet somewhere in or outside the motor as a filing trap as a precaution.
It just sucks that this happens now as I have cash flow problems (none) and to use my credit card makes me nervous because unfortunately the CC is an emergency money source.
At least I still have my silver, bad time to sell it though.
I feel like a VLT gambler though, what's a few more dollars as I look at a new motor like it was a video lotto terminal! How long can I go with a nude bike? When do I get that call for a job?!
Oh well, at least I am still better off than 2/3rds of the worlds population.
...May even be a good idea to strategically place a magnet somewhere in or outside the motor as a filing trap as a precaution...
Interesting idea.. Now to stare at a motor for a while and figure out where that spot could/would be.....
One could replace the wrist pin and crank pin with a magnet.
Just kidding. har har
A strong neodymium magnet(s) near the transfer ports? Would they catch the crap before it reached your piston and cylinder?
Lot of wind in there.
I have very little as well. Which is why I don't use these bikes as transportation. I have my trucks for that. :D
I wonder if anybody knows if there is a quality crankshaft out there that will fit on these engines, like a Kawasaki, Honda, Yamaha, Suzuki crankshaft?
I know they look quite similar, but I suppose if they would fit we would know about it.
I would just like to know I can get from point 'A' to point 'B' without worrying about a catastrophic engine failure. It's not like I would take my motorized bicycle to a time sensitive appointment and expect to get there, or go more than 10-15 k's from home lest I got to peddle back.
I've been bitten once, now I'm twice shy!
a nice three piece crank that bolts together so it can't get out of true and makes for easy big-end bearing replacement
Yeah really, we can change all the bearings, but that one, (with reasonable ease) it,s like having a strong chain with a lead link, it's only as strong as the weakest link.
But then again all my other stock bearings are in perfect condition.
