Black_Moons
Hi, I recently took apart my carb, installed a new air filter (huge one) and made a longer intake.. After sealing the intake all nicely, Im still getting a lot of white smoke that im almost sure was not there before I took apart the carb, And it seems the exhaust is driping oil and the sparkplug is coated in gas after low/mid rpm idle for a few mins.
Im wondering if maybe the main jet is spueing unatomised gas into the engine if its not sealed properly? I tryed taking the carb apart and unscrewing it, cleaning and rescrewing it in... did'nt seem to help much if at all.
Should I apply some kinda sealant to the main jet threads?
I also have the E clip at the lowest part, because it allways used to run a little lean before I redid the intake and air filter (There may of been a small air leak)
Smoke does not go away after idleing for 5 mins warming it up...
Also, iv adjusted the idle fuel mix screw and it starts to rev high at anything more then about 3/4 of a turn out. Adjusting screw does not seem to affect the smoke. Smokes more with more throttle applyed.
