So I have a Schwinn Ranger 26" mountain bike with an 80cc motor and the HD SBP Shift Kit installed. I thought my engine was doing quite well before I had the shift kit - 44 tooth sprocket I was going around 28 MPH top speed. I already had about 200 miles and was definitely way past the break in point, so I decided to order the shift kit.
However, since the first test ride with the kit (about 150 miles ago and many attempts at tuning everything,) I am able to top out in 4th, 5th, 6th and 7th gear all around 26-30 mph (varies as I ride down roads full throttling.) The difference between 4th and 7th (of course) is the extreme difference in RPMs. When I'm in 7th, it is a very low RPM, but it just stays steady at its pace. So it's like I'm hitting a brick wall in top speed on a level road.
For going downhill it's not much of a different story. I have noticed that when I am using the muffler that came with the kit, I will hit about 30-31 mph (so its not much of any advantage) but when I use my "banana" expansion chamber (no muffler) I have hit 35.7 mph going downhill in 7th (but going 29 mph before starting the downhill). In addition, the expansion chamber gives it better acceleration and generally leans towards a slightly higher top speed still up to 30 mph.
But after seeing so many videos about the shift kit (including SBP's promotional video) my engine seems comparably weak both in top speed and acceleration. Others seem to have the ability to cruise at 35+ no problem. I don't see my setup as much different, and I am not a particularly heavy rider (190 lb) so I just want to know what I can do to boost this setup.
So my engine setup is basically standard (NT carb, standard intake, standard muffler), and I am using a 32:1 fuel mixture. The fuel economy is probably around 80-100 mpg. However, I had rebuilt my engine after it had been on a different bike frame (it was truly a dud before though, only could go 15-20 mph with standard chain setup and it leaked gas throughout every gasket.) But after about 400 miles of riding it originally, I decided to pull it off the frame only to find out the jug was chipped in multiple places along the chrome liner.
My engine rebuild consisted of:
- New Jug
- New Piston + rings + wrist pins + piston rod (got the ring gap about perfect)
- All new engine gaskets
- New Shaft seals
- New magneto, coil, spark plug
But the end result: an engine that can idle well, doesn't leak fuel, doesn't have intake/carb leaks, doesn't really 4 stroke, has proper ring gap, spark plug gap, head torquing, 32:1 fuel, doesn't have much drag in clutch shaft area, pedaling is easy, bike wheels don't rub brakes, and bike wheels spin well.
I just really wanna use my bike to its greatest potential, and I don't think my engine is pulling it.
If any of you have questions, thoughts, or suggestions, please post!
I'd like to know what my options are, what things I should consider checking, your similar experiences, and any kind of insight. Thanks for reading!!
SomeGuy
- New Jug
- New Shaft seals
SomeGuy
