Skyhawk Frame Gas Cap Issues???
runnermike
936
Sanford, FL
Any of you guys with the skyhawk frame have issues with vapor lock? I have to dang near have the cap all the loose! Am I doing something wrong?
Any advice is greatly appreciated.
Thanks!
Mike
wing nut
128
warren p.a.
mike ,
i havent gotten mine running yet but when i read this i went and checked mine
sure enough the tiny vent hole was plugged
maybe thats what happened to yours
i used a needle for mine ..thank you for alerting me to this as well
hope it works out for you
runnermike
936
Sanford, FL
good news wing nut, but I drilled mine out with a slightly bigger drill bit than the hole and I'm still having the same issue. Guess I'm going to have to do some more detective work! LOL
wing nut
128
warren p.a.
i pulled the white cord off mine & the black inner cap off & found a rubber gasket ..with no possible way to vent either way
looks like i gotta address that issue ..vent it , or remove it
wing nut
128
warren p.a.
cool ..does doing that allow fuel to slosh out ?
im going to heat up a needle & melt thru that rubber gasket
hopefully that will allow it to vent and not allow fuel to come out
