silver solder?
Oh, and THANK YOU GEARNUT, for the clarification. I thought I was being clear, and concise, but I also used to think I was witty and clever in my verbosity when drunk, and it turns out I was just a jerk.
:$...if I weren't mis-understood, I wouldn't be understood at all...
And, as always, thank you ALL for your input and foods for thought.
Halfevil
At work we use the 2part epoxy sealer from Caswell and it works very well on the over 20 tanks we have done over the past 4 years. Can't say the same about a few tanks that had been done with some gray sludge. The Caswell sealer is clear.
And is that a two part epoxy? How long have the tanks lasted?
I've only seen the aforementioned grey/off-white sludge which, even with AMPLE cure time, have lifted from the tank within a month or twos time at most...and the cloggy nightmares usually start sooner.
3 years so far on the on the 2 tanks he has not sold the bikes a concourse and a Dneper
at the same time i also did a poly tank that had a crack for a Tanaka powered weedeater that I could not find a replacement tank for and its still holding up
yeah the casewll is 2part epoxy clear
