I bought a shift kit off E-bay looks like ole stile from what the
pictures. I know I should have bought the HD & most likely will
buy the HD flywheel. But here is what I can see a problem now.
It came with two sprockets a 36 tooth & a 44 tooth. Both are to
wide for the bike chain.
No remember I have never installed one. No info in the kit. Do I
use the sprocket that came on the bike to run the chain to the rear
changer & then use one of the two gears for the jack shaft chain. This
sucks when there is little to no instructions to go by. I have looked
on You tube but other than Fabians instructions there nothing & he
just shows building a sprocket cluster . I need help? The bike I bought
is a 7 speed Kent 26 inch wheel cruiser.
Fly
Fly
