Schwinn Landmark - Finished!
kevinkrg6
First Build.
-Schwinn Landmark (walmart)
-Grubee GT5 66cc
-#41 Chain
-Gasbike Universal Mount (redrilled studs for 5/16 bolts)
-Manic Mechanic Hub Adaptor and 40t Sprocket
-66cc Boost Bottle
-Alarm System.
Finally Finished, YAY!
Nice job beautiful motor assisted cruiser!
were there any special requirements on the handle bar grip shifter conflicts with kit etc.. Thanks
I know another member on here had no problems with the same bike. I had so many problems with the engine sprock being too far to the right, and the rear too far to the left. I had to modify a lot.
I recommend a single speed bike.
From the get go I should have bought a single speed rear wheel.
Maybe his motor being a 49cc made the diff? All I know is I know nothing
except how to read. I was wondering what you had to do and the cost associated with lining up the sprocket, also wouldnt there be trouble with the coaster brake on a single speed as I said I am not in the know. I already purchased the landmark online. Thanks for the reply
Your gonna love this lol....
Don't worry though, your purchase was fine out of all honesty. It is a good bike. But my experience was crazy.
I spent a month trying to get this thing lined up. I bought the manic mechanic hub adaptor and sprocket for $70 (ever heard of it? It's not necessary, but a great purchase for any bike. It drives the wheel not the spokes). It still didn't help.
Long story short, I took it to a place that builds custom motorcycles, and the total came out to $275 for his mods (O.O OMG SO EXPENSIVE!). I could have bought a new bike! He helped me make a lot of little (unnecessary) mods and other stuff, but what he really did was put spacers on the axle, and took the sprocket, and grinded it down so it would fit closer to the spokes. THEN my bike worked!
Your bike will very likely cost more than the cost of the plain bike and the engine kit. Everyone needs extra parts. Also a helmet, etc. There are members who will just say off the bat that their budget is $1000.
You shouldn't need that much though. What I would recommend is simply putting on your kit and seeing if it works. If you have trouble with alignment, you can buy the Manic Mechanic hub adaptor if the sprocket needs moved out (away from the wheel, the hub can adjust either way though), or a single speed wheel (meaning one gear only, $60) if the sprocket needs moved in, towards the wheel. You would only have one speed (duh), but that's all you need. Then you can use spacers (washers) on the axle to adjust. MUCH cheaper!
Even if you don't spend the money, if you have it set aside, there is a lot of great stuff to buy for your bike!
Expansion chambers will give you extra speed and power, a speedometer is pretty useful, visual mods, and the list goes on.
I can pretty much guarantee the build won't be plug and play for you though. It's a cruiser so you'll at least have to mod the mounts.
It's really a snazzy looking bike though. Good luck!
Thank you very much for the much needed info, I really appreciate it
I think I'm more nervous than before but that may be a good thingzpt..Thanks again
