J joey2point0 New Member May 8, 2013 #1 Hey Guys, I FINALLY Completed my motor bike and couldn't be more pleased, I basically started from a bare metal frame and built it how I wanted it. Attachments test2.jpg 819.8 KB · Views: 399 test.jpg 287.6 KB · Views: 342
wheelbender6 Well-Known Member May 8, 2013 #2 Wow. You really dressed up the cables and wiring. Where did you end up mounting the coil?
J joey2point0 New Member May 8, 2013 #3 Thanks! I really wanted a clean look. The coil is attached to the front motor mount, I drilled and taped a hole on the mount part and put a bolt through it. Since I have heat wrap the coil stays at a fine temperature.
