ruppster
I'm mounting a grubee 66cc with a sbp shift kit in a '50 panther frame and I have a couple of issues. I know I read at one point someone having the same issues but I don't remember the remedy.
In order to keep the chain from contacting the motor on the clutch side I have to raise the motor high in the frame. I have it as high as I can get it and the chain is still touching lightly. If I keep it at this height I'll have to buy a straight carb mount because the throttle cable will get kinked by the frame. I was thinking about making some 1/4" thick aluminum spacers to go between the kit and the flat of the rear mounting clamps which would move the motor forward slightly but I don't know if it will have any ill effects. Other than a smaller front sprocket I can't think of anything else. I'm not crazy about how far back and high it sits in the frame either. Any sound advice or ideas would be welcome. I plan on contacting sbp Monday but some of you guys are really clever and I'd like to hear what you have for ideas.
