SBP pipe installed
leo
got in a quickie test ride before the rain today. loving it so far, more later...
quick questions...
1) do the silicone sleeves shrink to fit on the copper?
i noticed in SBP's tutorial that the chamber-header seam is the only one showing clamps being used.
2) when installing heat wrap, do you just go over all the sleeves, clamps and all? or do you guys seal them some other way, then wrap the pipe?
The sleeves don't shrink, & you should use the hose clamps on both ends of the sleeves so the internal pressure doesn't blow the sleeve off.
Wrap the heat wrap over all the parts.
