Go back to to permalink #13.
The spindle was something I made from some black steel pipes.
3" long pieces of pipe inserted into each other.
It took 4 sizes of pipe to work down to 1/2" internal diameter. 1",3/4", 1/2" and 3/8"
I turned the outside dimension down on each size until they fit inside each other. Not fun or quick. Then I heated them with an acetylene torch and brazed the ends to make them as one. Drilled and tapped 5/16" set screws to anchor the to the clutch shaft.
It's far easier to dish out the $20 and buy one from BMP. I just wanted to see if i could do it myself. Cut each groove with a hack saw. Probably a total of 8 hrs or so. It's one heavy spindle..
