DRBS Member Jun 24, 2014 #1 I have a runtong carb what is the float level turning carb upside down I think its too low I cant seem to get a good steady pace it bogs and then runs good at about every 15 seconds any suggestions
maniac57 Old, Fat, and still faster than you Jun 24, 2014 #2 I THINK it's 21mm from gasket surface to top of float when turned over.... but it's been awhile. Might want to search for "float level" in SEARCH BOX
MotorBicycleRacing Well-Known Member Jun 24, 2014 #3 maniac57 said: I THINK it's 21mm from gasket surface to top of float when turned over.... but it's been awhile. Might want to search for "float level" in SEARCH BOX Click to expand... The RT or RunTong carb has a plastic float with no way to adjust the level. Has a rubber tipped fuel needle valve too. What jet are you using?
