Hello
I just got a brand new RT 15mm high
performance Carb from Dax. I plan on putting it on my 2 stroke 66/80cc, center mount, direct chain drive MB. My carb came with 5 different jets, a 60, a 65, a 70, a 75 (already installed), and an 80. My questions are: (1) which jet should I use? My current NT carb has been bogging down a bit at the higher RPMs with a very unstable idle that seems impossible to set, when idle it up it tends to race and when idled down it won't stay going, even after I installed a washer at the intake manifold. I'm hoping that this new carb will solve these problems and provide a little bit more power for the hills I ride. (2) Can I really expect much more power or torque from the RT? (3) Should I remove the washer from the NT carb and put it in the RT carb or will that not be necessary? I plan on installing it this Saturday and any tips or advice is much appreciated.
