Replace Titan with HF Predator?
skyl4rk
I have a dead Titan and would like to replace it. I am wondering if any of the HF motors will have the same shaft and mount for the Titan clutch/gearbox?
Don't ditch that titan folks are always looking for used parts, worth some thing. Wassup with the titan, how many miles on it?
If the Titan has the 3-spring (and shoes) clutch which it probably does, there are no compatable Pedators for a swap.......different shaft. Sell the Titan, buy a Pred....they're cheap.
dnut
Bought one of the HF 99CC for mocking up our Q-Matic drive to the crankcase and only paid $79.20 plus shipping. You can get them to honor a 20% coupon for online ordering, just ask them.
Have fun,
I had a lot of problems with the idle jet o-ring for about a year and then one day it just quit while riding. I couldn't get it to start again. I don't know what it is. It could be something simple. I was pretty tired of dealing with it. Its been sitting outside for a year.
I may see if I can get it to start up again tomorrow.
YO sky if the only reason you want to get an HF is because the titan is kaput maybe with the board we can get it going. If that thing has compression and turns over chances are it can run again. Make sure theres no water in the crankcase and do an oil change on it. It will run again.
It sounds like a simple carburation issue. A favorite line from the old Bonnie and Clyde movie: "dirt, dirt in the fuel line, just blowed it away". EJ Crebb's or something like that....their getaway driver said that rotfl
Clean the carb out as well. Fresh gasoline with a good fuel filter on these little 49cc engines is a must. Good luck.
dnut
The carbs on HS/Titan clog up real easy, especially early on. My first one worked right for ~100 miles, then never worked right again.
Sometimes it's better just to replace the carb, but it may take a few carb rebuilds before you decide that's the best way.
20% Off Any Item at Harbor Freight Tools
Coupon Code : INSURE20
Coupon not valid on any of the following -- prior purchases, gift cards, Inside Track Club membership, extended service plans, Compressors, Generators, Tool Cabinets, Welders, Floor Jacks, Campbell Hausfeld products, open box items, or Blowout Sale items.
Have fun,
How did you get them to ship it? On the web site it says purchase in store only and when I called to try they told me they would not ship it.
thx???
