My ride: 66 with NT carb
I have roughly 600 miles on my bike, keep the oil/gas ratio a lil high because of it being a bushing, nonbearing motor. 20:1
It has always ran boggy in the idle to 3/4 throttle range regardless of needle height. Didn't really matter as when it was WOT, it screamed like a banshee. Since the majority of my commute is basically down one really long road with no stop signs it was WOT or close to it, so not a prob.
I had last week off work so I had time to tinker with bike. I assumed the boggy on low end was due to air leak so checked and sure enough had a leak at carb to intake joint. Fixed leak, took test rides and plug chops at different needle positions, and now my low end is spot on. Only problem now is WOT is a dog. My main jet is too large and bogging out motor.
I have an expansion chamber from a kx65 I'm going to adapt to motor, was going to do it this week at work.
Do I go ahead and rejet now or wait and see how much difference the new exhaust will make? Ive heard both, that it will lean it out and that it will richen it up.
