nathpld123
is it normal if my bicycle die when its in idle mode? I sometimes tighten it but still die after few minutes.
There should be an idle speed screw on your carburetor. You didn't say which carb you have but they all usually have one. Have you tried increasing the idle speed by turning that screw in a little?
Well i moved the c-clip in the middle. So its now at 3rd lines from top. It did fixed my problem.
However im still confuse. Isnt it better if the C-Clip stays at the second from top? Cause thats what others recommended me to do and so i did it but it seems like the idle is not good that way.
PS: When i bought the kit the C-Clip was at third line.
