questions about nt carb
WildAlaskan
578
alaska
dont prime till you see it coimg out of the overflow cause you will eed to clean your air filtur more frequently
the primer is a weak spot my cap broke off smehow and the pin that pushes the float down jammed the float causng massive flooding i used a bolt to seal the hole and took the choke off cause it kept vibrating closed
