greaser_monkey_87
I need a little advice with my electrical system. It works, and all the wiring is correct, but my battery does not charge as well as I would like. Before I get into details, let me add that this is not a kit bike, and there is no way to draw any power from the engine, which is why I built the system that I have. So here is my setup.
I started with a tire-driven generator. I wired this to a rectifier/regulator to convert the generator current to DC. I am using a 12v, 1.2Ah battery and I am using LED's for my headlight and brake light. The system peaks at 17-18v at speed.
The problem: the battery charges fine when the headlight is off, but when I run the headlight the battery drains, not super fast, but what I guess would be a normal amount for a battery not hooked up to a charging system.
What I theorize is the cause: both lights can run on anywhere from 8-30v, so the headlight is taking whatever is being thrown at it, i.e sucking up all the current in the system. This doesn't cause a problem with the brake light, because the brake light is only on when I'm stopping (tail light is separate from brake light).
On to my question: what is the best way to limit current to the headlight, so that the battery will charge while the headlight is on? A resistor? A zener diode? I considered a voltage regulator, but a linear regulator will just bleed excess voltage to ground, not allow it to go to the battery. I'm not sure if a switching mode regulator will do what I want it to or not.
To keep replies short and simple, I don't need a long-winded explanation of electrical theory, or why a certain part will work better. I just need to know which part will work best, and any pertinent info related to the installation/application of that part. I can get to radio shack faster than I can read a lot of extraneous info on theory, lol. Not trying to be rude, just that installing the right part doesn't require understanding the theory behind it. So just trying to help keep the answers as short and simple as possible. Thanks
