H homejones New Member Jan 5, 2012 #1 Anyone try this combination (Predator 99cc + SBP 4-stroke shift kit)? Will this work? I think I would need the AGK clutch, but not sure this will work with the SBP shift kit...
The_Aleman Active Member Jan 5, 2012 #2 It could work with some modifications to the mount. It would be almost 12" wide tho. You just need to figure out how to connect the jackshaft chain.
H homejones New Member Jan 5, 2012 #3 Could I just hook-up the clutch to the jackshaft sprocket on the shift kit...? I guess the shift kit mount is the biggest question/issue...
The_Aleman Active Member Jan 5, 2012 #4 Theoretically, you hook up the output of the AGK jackshaft to the 17T input of the SBP jackshaft. The clutch would be on the motor shaft like normal. No one's done it here yet, so you'd be the first.
