Porting templates
thepolarpandabear
Hey guys I'm looking for some kind of a diagram or template to tell me how much porting I should do to my intake. Thanks in advance dunts
On the same topic here... What kind of dremel bit is needed for porting. Does someone have a part number for the bit? Thanks
The easiest way would be to cut your gasket to match the jug, then use that for a template for your intake :) If the gasket is still new, rub a little chain oil on the jug surface, then snug the gasket down under the intake, that'll give you a good "imprint" of the port on the gasket to go by
If you're porting the jug, that's a different can of worms.
gl
gokart, depends on the intake, if its aluminum one of these bits works great pic, but for steel a grinding stone is better, just use a stone small enough to get into the port.
gl
