Velodrome
So. My HS 49cc on the Chief build was always a little iffy at wide open throttle cutting out every 5-10 sec for about 2 revolutions. Just a little cut then fine. Annoying but livable. NOW it still does that, but at part throttle; like just off idle; it DIES! Opening the throttle slowly or anything less than WOT or idle it wont run. If I take it from idle to WOT it will go with the aforementioned hesitation. I have so far: Disassembled the carb and cleaned. The idle jet is good. and the guts were blasted out with carb cleaner after removing the main jet. No difference. I have replaced the coil and wire. No change. I have replaced the Chinese plug with a Champion Copper Plus Z9Y properly gapped with no change... If I had hair I would have pulled it out by now and be back to normal... I just changed out the kill switch assembly and its still no go.
HELP! HERE is the carb in question: http://www.affordablegokarts.com/mm...ode=A&Product_Code=2707&Category_Code=MTRBK49
