PLUG REACH lifan F152 vs DB30
MotoMagz
:-||The DB30 is the engine that comes on the doodlebug minibike.The f152 lifan is identical and parts are interchangable.Why does the lifan f152 plug have a longer reach? I ask because the DB30 plug is also much shorter at the ceramic end which will help with clearance issues. take look...
Somebody !!! Anyone !!!! Bulluer!!! Why are they the same motor with differnt plugs.The only other difference between the to motors is the Lifan uses both oil fill openings and the Doodle bug has one closed off with no plug.
